Heater Problems?
Old Oct 31, 2003 | 01:11 AM
  #21
GSi's Avatar
GSi
[QUOTE]Originally posted by cheshire_carper
Old Oct 31, 2003 | 02:11 AM
  #22
Nick Graves's Avatar
I would check the cooling system carefully, it could be a head gasket problem.
Below fan setting #3, there is only ram effect, so the heater only puts out as the speed increases. Above that, it should be fairly consistent.
VTEC will warm up the water, but the effect should be load-dependent, not rev-dependent.
Old Oct 31, 2003 | 02:29 AM
  #23
JamieS2K's Avatar
This heater thing happened to me once, I realised what it was a few miles down the road when the water pump exploded ...
Old Oct 31, 2003 | 03:08 AM
  #24
ChrisWells's Avatar
This is getting worse and worse I'll be checking everything tonight
Old Oct 31, 2003 | 03:17 AM
  #25
GSi's Avatar
GSi
Chris,
FWIW, I just had my head gasket replaced and I wasn't experiencing any cooling/heating probs. Mind you it was a little strange as the fulid exchange seemed to be in the wrong direction.
Old Oct 31, 2003 | 04:21 AM
  #26
Chris Type R's Avatar
Does the heater route through the pollen filter ? Might be worth checking that out as well. It's located passenger side near the base of the bonnet under the black plastic cover, and is a B**** to remove & replace.
Old Oct 31, 2003 | 10:35 AM
  #27
Rob M's Avatar
It was interesting having the head problem in the MR2, got down to 30 miles between coolant (water) refills before i had a replacement engine.
Old Oct 31, 2003 | 11:21 AM
  #28
ChrisWells's Avatar
Water coolant was just below the low mark so I topped it up then took her for a test and found that:
. heat started coming though after 300 yds then went cold again.
. rolling @ 2k - cold.
. up to 3k - warmish
. up to 4k - hot
. down to 3k - warmish
. down to 2k - cold
Sod it and roasting. All ok after that. I hope that topping it up sorted the problem but I am concerned as to where the fluid went I was up to max a couple of weeks ago. The dip stick is clear so hopefully not head gasket. I'll just keep an eye on the water level and take it from there.
Old Oct 31, 2003 | 11:32 AM
  #29
I'd keep an eye on it.
Check the inside of the oil cap for mayonnaise.
I would recommend a cylinder pressure test, if you are at all suspicious the problem has returned.
Old Oct 31, 2003 | 11:33 AM
  #30
Beardie's Avatar
Chris.
Wait until the engines completely cold and check the level in the radiator.
If you've got air into the system, there's a possibility that it wont flow in from the topup tank.
Keep a towel handy as the system may still be under pressure even though it's cold.
The symptoms of higher temps at higher revs is definitely showing a possibility of lack of coolant in the engine. The higher the revs, the faster the remaining collant goes through, the better the heat exchange. Slow revs, very little manages to get into the heater matrix, therefor colder.
Anybody know if there's a bleed valve on the coolant system?
