Help - Alpine Patch lead not working.
I am now pulling my hair out - what's left of it!
I have got the autoleads harness to connect to the dash controls and the alpine patch lead to fit to the 9846R HU and I am following the instructions as follows:
1 - Keys out of the ignition.
2 - Plug patch lead into interface box.
3 - Connect ISO blocks and aerial to HU (not the jack plug).
4 - Switch on HU and tune in radio station and store.
5 - Switch off ignition and remove keys.
6 - Turn ignition on and let HU power on.
7 - Turn off HU and plug in jack plug.
8 - Turn HU back on and test dash controls.
I have tried over a dozen times now and between each attempt I have reset the HU and removed all connections from the autoleads unit and left for well over a minute like the instructions say, and still no dash controls apart from mute!
Can any of you shine any light onto what I am doing wrong?
Thanks.
Thanks.
Well after a few days of persistence I am still baffled.
I have been searching through the forum and all I seem to have come across is similar problems of only having mute.
At this rate I will be sending it all back and using the OEM.
Just one more question. I have an '06 model. Were there any changes on this model year that are different with the stereo?
I also contacted the place I bought all of the kit off and they talked me through the wiring while sat in the car and they too were baffled that I couldn't get it to work. Tried all sorts of disconnecting/connecting wires in different orders etc.
Anyway, thanks for the replys, but as I am well and truely p****d off with it, all the gear went back and the OEM HU is staying - until I struggle with having to swap cd's all of the time again!
Cheers.
I can't remember if the mute button light came on on the dash when it was pressed, but when I did press the dash mute button the stereo was muted. The display on the stereo screen when it was muted said 'interupt'.
Hope that makes more sense.
Ewan
