Help with the door dome light switch
on mine the button just unscrews/bolts from the frame
it should make to -ve through the body with door open (depressed)
if you disconnect the wire and touch on bare body (on the car
if the light works this proves the switch is at fault.
if not would think about tracing the wiring
)if the light works this proves the switch is at fault.
Thank you all for your replies. Much appreciated.
Is it easy to take the door light switch off? When i saw it, it looks like is quite good attached to the body frame.Is it just unclip it because i could not see any screws over there.
Chris
Chris
solitarycheese
Oct 8, 2014 08:27 AM
