help needed piping up coolant system
right then, my f20c install is at the stage where i need to pipe up the coolant system and fit remote oil filter kit, (space is tight)
i have a pro ally race radiator with no pressure cap,an ally header tank at highest point on coolant system(with pressure cap). has 2x outlets and a breather hose outlet
i need to bypass heaters,pipe up header tank in to coolant system(not sure where),and fit remote filter kit. anyone got any info on how to do all these things or better still, a detailed diagram! cheers
suggest for the coolant system you just look at the manual diagram for where the pipes go.
I bypassed the heater on my H22 Civic - it was simply a connector that joined the two hoses that went into the heater matrix.
lovegroova
10-03-2015 05:20 AM
Vinny_GPW-S2K
04-06-2012 04:51 PM
08s2000CRbackinblack
06-03-2010 05:33 AM
