Intro and Enkei RPF1
Old 02-21-2014, 05:04 AM
Harlo's Avatar
Default Intro and Enkei RPF1
Hi All
Been a member for a little while now but thought I would introduce myself properly and ask a question if i may
So, I'm Jason, live in Shropshire, UK and purchased my 2006 Silverstone Grey S2000 GT 3 weeks ago!
Big change for me, as I was rolling around in a 2007 Focus ST for the past couple years fully modified running way to much power for a FWD hot hatch but loved every moment - Although a big change, I'm very impressed with the S2K so far and currently looking at my next modification, wheels!
Have done a lot of research around this subject and fancy a set of RPF1s 17x8 45 Fronts and 17x9 45 Rear - Want to run 215/ 245 tyres too.
Only modification the car has to date in a K&N induction kit; my question is at stock ride right will any front/ rear fender mods be needed such as rolling, pulling, trimming, bumper tab relocate etc?
Cheers,
Jason
Old 02-21-2014, 05:06 AM
UK Moderator
lovegroova's Avatar
This link is in "Read This First": https://www.s2ki.com/s2000/topic/104...se-wheels-fit/ hopefully the answer is there.
Old 02-21-2014, 05:17 AM
WinFreak's Avatar
Welcome
You probably won't need any rolling but it might rub if you load the car up a lot or really lean it through the corners maybe
It'll look rubbish though with a big arch gap and fancy wide wheels poking out
Old 02-22-2014, 12:47 AM
Harlo's Avatar
Cheers guys; coilovers are on the list but if I go for a conservative drop probably going to need arch work.
Thanks for the input :thumbsup:
Old 02-27-2014, 03:22 PM
MeisterR's Avatar
Well, coilovers we have in stock for the S2000.
Depends on your budget and usage, but quite a few choices.
We are also now the UK Distributor for Enkei wheels.
We will be placing an order with Enkei next week, and we also have a 15% discount running until the initial stock arrive (basically a discount for your patient).
So if you want a set of RPF1, now it would be a great time.
Jerrick
Old 02-27-2014, 04:19 PM
2ndy's Avatar
Roll the lip off the arches and the wheels will probably clear fine
Old 02-28-2014, 04:49 AM
flanders's Avatar
That and use 225/45 and 255/40 tires instead.
Hottman77
01-23-2015 02:51 PM
fernando.
09-23-2011 12:26 PM
DanZilla
08-14-2009 10:23 AM
baggelis
02-07-2009 02:19 PM
gotem
08-21-2007 09:29 AM
Quick Reply: Intro and Enkei RPF1
