MB's modification thread...
Thanks Simon.
UF, I bought some small MDF spacer rings just in case! Might need some advice on these crossover things and how to fit them in the door
And then how to set the head unit up!
Fitting the crossovers in the doors is easy, assuming you've had the door cards off - you just shave off some of the styrofoam block on the doorcard and screw them to it - as long as they sit flush, they'll fit just fine.
Take the existing feed from the OEM harness ( make sure you check with is + and - ) and then wire that to the input on the crossover, then run the wires to the tweeter / midrange.
In each door;
Green/yellow = +
Green/Black = +
If you're never going to refit the original speakers, hack the plugs off and use nipples and cups connectors to attach new wires, if you're going to put them back in - hack them off but leave enough wire to reattach them
There is a hole in the doorskin that the wires for the window controls / doormirror switches come out of that you can run the wires through to the croosovers. The tweeters are fastened to the door cards in the OEM location and the wires can be attached and routed around the door cards to the tweeters.
PaulF / Lovegroova can also direct you on this and Lovegroova in particular is the man to chat to about HU setup
In each door;
Green/yellow = +
Green/Black = +
Thanks UF
So there new wires to be run from the HU to the crossover? THink it's one of those things I can suss once I have the door card off! I have to visualise things
No - you don't want to get into trying to run new cables into the doors
That's a pig of a job!
You use the wires from the midrange already in the car as the feed for the crossovers, the crossovers then feed the new tweeter and midrange.
The existing tweeter has a crappy crossover hardwired to the back of it to convert the full range signal it piggybacks off the existing midrange
That's a pig of a job!You use the wires from the midrange already in the car as the feed for the crossovers, the crossovers then feed the new tweeter and midrange.
