need help! cant remove wheels!
I need help! I have a set of mf10's - you may ask why i want to take these off the car, other than to put new tyres on? but i dont have the locking nut! Last owner is in Japan so its not something readily available to ask. Cut of the locking nut is three semi circular groves at 120 degree intervals around a roundish mass. I am going to LM and am worried about getting a puncture....
Basically can i do one of the following?
Is the nut standard) ie if i buy a set of older mugen locking wheel nuts - will they fit ?
does anyone have a spare locking nut? that may fit or that i can get a copy machined up if it proves to fit?
speak to OEM / Garage supplier and get the key?
extreme- can i drill / cut the existing nuts( the wheels are dirty but otherwise unmarked)
I may be wrong but I'm sure a few people have said they have had to have them drilled off when they have lost the nut.
I would get it done before LM - you so know you will be in trouble otherwise
Originally Posted by B B,Jun 4 2007, 06:50 AM
Which I guess proves that if a thief is determined enough he can also buy this equipment & nick your wheels.
I got one of my nuts drilled once. All other attepts to get it off failed.
Just took the car to a garage, 5 mins later it was done.
There was a small mark left on the wheel, but no other choice.
