polybush compliance bushes
Im in the process of polybushing my car with the polybush kit. This comes with replacement compliance bushes but reading through the forum there are a few mentions of this bush been too stiff and restricting the wishbones movement and also making the front end very hard. So, can anyone who's got the polybush compliance ones fitted give me some feedback on how they've found found them. Much as im reluctant to buy spoon/mugan ones to replace the new ones ive already got in the kit id rather do it at this stage than get them fitted, geo done and then find i need to swop them a few months down the road.
I've had the whole set fitted to mine for a month or so and can't say I notice much difference to how it was before, yes it's all a bit stiffer but I've also fitted a coilover set.. I wouldn't call it hard in any way
How free did the movement on the lower wishbone seem before you put it all back together??
Just fit them you will be fine, they are a Pig to press in, and get some copaslip on the sleeves/bolts. When I first fitted mine I made a balls up,on one I put the 2 cam adjusters 180 degrees from each other...because you can't really see the top cam adjuster, so just be aware of that.
Originally Posted by yorkies2k' timestamp='1326960819' post='21331177
[quote name='WinFreak' timestamp='1326959251' post='21331155']
[/quote]
Cheers
