rear camber gpne wrong...really wrong!
That's where pics would help.
It doesn't sound like a whack, when I hit the kerb with mine it was the other way around bottom was in and top was out.
Unless the inside of the wheel has hit a rock or similar I suppose? That would be unusual!
Still needs to be checked out on four wheel alignment rig.
If its visibly out then something is definitely bent.
A less likely scenario would be loose wheel nuts. Isn't this waht Alonso's wheel looked like beofre it came off at the weekend? You could check wheel nut tightness as a precaution tho'.
Originally Posted by hoppingdeth,Jul 29 2009, 10:14 AM
Take it to Tony at WIM and get it properly checked.
www.centergravity.co.uk
Originally Posted by NineBolts,Jul 29 2009, 11:18 AM
Port or Starboard
As you have spotted something amiss with your car I would not drive it, unless you are taking it to somewhere local to get it looked at. The S has a reputation (for one reason or another) for being tricky in concern road/weather conditions.
You'd be so gutted if you crashed it on your way to work, after you'd spotted this problem. Also think about other motorists and their safety. I'd never knowingly drive an unsafe car. I'm not saying your car is unsafe, but there's no harm airing on the side of caution.
Originally Posted by LTB,Jul 29 2009, 10:27 AM
His location is down as 'West Midlands' so Center Gravity would be a lot closer.
TokeMadBowls420
Jun 8, 2004 07:47 PM
