rear hub
the studs are pressed in from the back. You have to pop the ball joints to take the hub off. The old lugs have to be pressed out and new ones pressed in. You cannot hammer them. I did all four of mine to go to longer studs. You also have to press out the bearing and put a new bearing in. You need a 30 ton press.
It is explained in detail here:
http://robrobinette.com/S2000Bearing.htm
Do not buy cheap ebay studs. You life depends on it. Get ARP studs. Getting everything and off costs the money. Do buy a spare hub either, no need for it. If read the thread to Rob Robinette you know all that.
