Rear Wheel Studs
Old Dec 30, 2006 | 12:37 AM
Ro_Ja Boy's Avatar
Default Rear Wheel Studs
Can anyone tell me how hard the installation of wheel studs on the rear of the S is? I have heard that the install is not as easy as the front, but wanted some input. I figured this forum is where most people that have extended wheels studs hang out.
Ryan
Old Dec 30, 2006 | 04:55 AM
cthree's Avatar
Administrator
You need to remove the hub.
Old Jan 2, 2007 | 08:15 AM
Ro_Ja Boy's Avatar
I got that, which I had to do for the fronts. However, I heard that the bearing is worse to deal with on the rears. Anyone comment?
Old Jan 2, 2007 | 08:31 AM
alejo's Avatar
Originally Posted by cthree,Dec 30 2006, 05:55 AM
"Burning bridges and building walls since 2000" - George W Bush
just saw this!
sorry for the thread jack ryan
Old Jan 2, 2007 | 09:17 AM
twohoos's Avatar
Maybe best to replace entire hub and bearing. The studs are tricky to press in correctly, which can lead to fitment/balance issues that'll have you replacing the hub and bearing anyway.
Old Jan 2, 2007 | 09:18 AM
Ro_Ja Boy's Avatar
Im looking to replace the rears with extended studs, so I cant just replace the hub and bearing. I have heard that Ill need to replace the rear bearings in the hub, but then again, I was told I would have to in the front and didnt need to. Just hoping someone has done it before that can help.
Ryan
Old Jan 2, 2007 | 09:23 AM
bc02's Avatar
you have to remove the entire knuckle.....and have the stock wheel bearing pressed out at a machine shop(its held in with 2,000 lbs pressure)....and then have a brand new wheel bearing pressed back in after the machinist will press in the longer studs and reasemble the hub onto the knuckle.....there is no other way....pressing out the wheel bearing ruins the race on it....that is why it has to be replaced with a brand new one.....its a pricey job and not that easy....GOOD LUCK, BILL
Old Jan 2, 2007 | 09:49 AM
Ro_Ja Boy's Avatar
Thanks Bill. Any idea on the cost of two new bearings? Thanks!
ryan
Old Jan 4, 2007 | 07:21 AM
bc02's Avatar
I picked both front up for $150...the rear is a tad more expensive because its a bigger bearing.......machine shop labor was $90 for both front.
maccax
Mar 3, 2015 05:51 AM
SuperKool
Feb 11, 2014 08:32 AM
Si2k
Oct 27, 2008 01:45 PM
goldenfri
Jul 5, 2006 09:45 AM
