Refurbed brake calipers
Old 12-07-2013, 09:30 AM
Childsy's Avatar
Default Refurbed brake calipers
My front left caliper is sticking..... Where's the best place for a refurbed replacement? Seen some on ebay but is there a particular seller on ebay that many people on here have bought from that they recommend?
Cheers ladies and gents
Old 12-07-2013, 10:56 AM
CynicG's Avatar
Bigg Red
Old 12-07-2013, 01:45 PM
J_B
J_B's Avatar
Interested to know this too. The front left has stuck on my car twice in 1 week now.
Old 12-07-2013, 03:02 PM
Childsy's Avatar
Originally Posted by CynicG
Bigg Red
Are they still providing this service? I guess I would need to remove my caliper and send it off to get refurbed by these guys? rather than just buying a refurbed caliper which I was looking to do.
Old 12-07-2013, 05:04 PM
noodels's Avatar
Just press foot on brake <pads removed> and clean piston from dirt build up lube it and push it in again.
Old 12-08-2013, 12:56 AM
Toms1989's Avatar
AMK or Shaftec, obtainable through local motorfactors, come with a 2 year warranty or 30k or so miles. Set you back about £60-£70 each
Old 12-08-2013, 03:54 AM
J_B
J_B's Avatar
Bigg Red
Are the Bigg Red brake caliper repair kits worth buying? At £20 and a few hours work they seem like quite a good way to go. Instructions would be nice too
Old 12-08-2013, 12:38 PM
Childsy's Avatar
My Sunday consisted in cleaning the car and then moving on to this dam caliper!! I removed the caliper, pushed the piston out and saw a fair bit of rust. Used some wet and dry to rub it down as best I could, cleaned it up, regreased, refitted, flushed through some new brake fluid, job done. The piston was a little bit sticky but not as bad as it was previously so will be looking to replace caliper after Xmas.
Old 12-09-2013, 11:19 AM
silverspark's Avatar
Look on E Bay & order 2 x Budweg caliper kits by Brakeparts.co.uk @ £33.95 each . The kit comes with everything you need to refurb the calipers yourself including the pistons which are the components that corrode and stick . If your reasonably confident it should be a steady Sunday mornings work . I originally pushed my rusted calipers out and cleaned up but this only buys you a few months & they will be sticking again . It's really not so difficult job and will save you a lot of hard earned .You will also need brake fluid to re bleed & replenish system as you may as well do the right thing and do a fluid change / bleed all 4 corners while you have the jacks out & wheels off - hope this helps !
Old 12-12-2013, 11:27 PM
J_B
J_B's Avatar
I decided to order a reconditioned caliper instead of refurbishing at home. £130 with a £30 refund when you send the old one back to them. I had the right hand one included in the sale of the car because the previous owner thought the right hand one was sticking, so I bought the left hand one as well so I can change both. Might be worth a look for anyone else having problems. They are refurbished by http://www.brake-eng.com/.
Sold by Brakes International. http://tinyurl.com/nfsvjez
For giggles I rang Honda about replacing both front calipers. £650 per side!
Fahad93
03-31-2019 08:18 AM
Cloudcapp
07-18-2017 06:37 PM
OldDogmeat
09-03-2012 09:41 PM
Quick Reply: Refurbed brake calipers
