Rounded a wheel nut - what now?
Lucky it wasn't the ABS sensor wire - now they check the lights work on the MOT you can't get around that one as easily...
can you screw a threaded bolt in the existing area,lock it with 2x or 3x nuts and undo
failing that a center punch <long >
Thanks all for the advice and help. For the record, I had to get these taken off by a welder today as they were totally mullered after hitting, drilling, kicking, hammering, breaking drills, chipping alloys,reverse screwing, etc. and still no movement.
Even with the welding they took a few attempts of heating and cooling before movement. It seems they were really tight and had started bonding/corroding to the alloys themselves. Never again will I use these things!
of a job that sounded to do...
