Sump removal
Old Nov 25, 2010 | 10:07 AM
rob2.2's Avatar
Banned
Default Sump removal
hi
ive seen theres a crossmember in the way,
can you take the sump off without removing the engine?
and hits and tips/ links welcome
thanks rob
Old Nov 25, 2010 | 11:09 AM
MB's Avatar
MB
Member
You can remove it without removing the engine Rob.
Andy Vey has done mine twice on my old S, give him a call.
Or, a 2 second search for "sump removal" revealed the following...
https://www.s2ki.com/search/forums?query=sump+removal
Old Nov 25, 2010 | 11:13 AM
rob2.2's Avatar
Banned
Andy Vey has done mine twice, give him a call.
hi mate,
thanks thats great,
i tried searching but obviously a bit special as was coming up with completely different things lol
will be updating my urgent help thread once taken caps off and can see the bearings, not looking forward to this as it will be an expensive find im sure
Thanks for your help tho MB
Old Nov 25, 2010 | 12:15 PM
Garage R's Avatar
just remove the brace. other than that just remove all the surrounding bolts
Old Nov 25, 2010 | 10:13 PM
TangoVTEC's Avatar
Remember to clear debris from the gasket/bond fitting face when putting it back on, and torque bolts in an opposing sequence as directed in the service manual, yes there are a lot lol!
Old Nov 26, 2010 | 12:22 AM
rob2.2's Avatar
Banned
thanks will be trying sat morning,
is there many items to remove before getting to the bearing caps?
Old Nov 26, 2010 | 12:49 AM
Stevie_P's Avatar
Best of luck Rob and sorry to hear of your predicament.
Hope you've got some thermals?. It's going to be bloody freezing over the weekend
Old Nov 26, 2010 | 12:51 AM
GhostWKD's Avatar
If you struggle to get it shifted, make sure you've got all the bolts, i was struggling to see how mine would come off, then realised i'd missed one bolt and it just came off pretty much once the last one was out (muppet!)
Old Nov 26, 2010 | 01:39 AM
buaan's Avatar
Take the sump off,
You'll see the baffle plate, under that is the oil bump assembly/lower block.
The oil pump is run by chain from the crank sprocket, I think you might need to take the chain case off to remove the chain if you want to remove this?
You'll be able to see the con rod caps through the lower block although cylinder 1 & 2 will probably be obstructed by the oil pump.
EDIT, I checked the service manual out of interest:
Get the service manual : http://www.spoonertuner.com/media/download...03_AP1_USDM.zip
pages 8-3 for the exploded sump/oil pump diagram.
8-9 shows you the removal of the oil pump.
Old Nov 26, 2010 | 07:58 AM
rob2.2's Avatar
Banned
Originally Posted by buaan,Nov 26 2010, 02:39 AM
Take the sump off,
You'll see the baffe plate, under that is the oil bump assembly/lower block.
cheers mate, awesome link
Greg Bell
Aug 15, 2016 05:01 PM
rob2.2
Feb 23, 2011 12:45 PM
harrison1990
Dec 18, 2010 05:06 PM
Black_SIIK
Jan 11, 2005 04:14 AM
Magius
Oct 10, 2004 11:49 PM
