Torque for Android - Video and Data
I got the same thing - you can fix it in RaceRender by creating a calculated field.
Add a bar graph (or gauge), then select the input as your Race Render csv file
Then click Setup
Towards the bottom of the screen you will see you can create 4 calculated fields
Call the first one "TP" select input field "Throttle Position" and "Multiply" by 1.2 (or look at the data file, find the maximum value there and calculate the figure required to get 100. i.e if yours is 79, then (1/79) x 100 = 1.266
Then use field TP as your data source
Then click Setup
You'll struggle as there aren't any camera screw to phone adapters out there, believe me I've searched.
Modifry and Panavise is best, or perhaps a new suction mount.
Not sure that would work though unless the top part unscrews from the base?
A decent phone mount is the best bet for the windscreen, but if you want the better view from up by the wind deflector, then modifry really is your best bet.
A suction cup on the wind deflector will just mean lots of vibration.
