Water leak into boot
Old Apr 11, 2026 | 02:27 AM
Dave Stephens's Avatar
Default Water leak into boot
Ive got a water leak into the boot. I'm aware of the vent seal from the rear bumper that needs re-sealing, I'm also aware that the rear light clusters need re-sealing.
There is another leak which appears to come from the boot lid bracketry which is the square section hollow brackets. Does anybody have any suggestions?
Thanks
Dave Stephens
Old Apr 13, 2026 | 04:13 AM
Chuck S's Avatar
Roofs can leak from above, around the edge of the fabric roof.
These leaks sometimes happen after attempts to ream the dust and tiny leaves out the little drain hoses with a sharp wire. There are past posts describing a safer way to clean the drains. Also possible when in-expertly installing a new roof.
https://www.google.com/search?client...3Awww.s2ki.com
-- Chuck
Old Apr 14, 2026 | 02:34 AM
devon2k's Avatar
Active Streak: 30 Days
Remove the 2 small plastic trim pieces between the boot hinge line and hood and seal the panel joint in there with Captain Tolley's Creeping Crack Cure or whatever else you might prefer.......silicone rubber etc. There's quite a lot of info on here about it. Captain Tolley's is brilliant stuff.
Old Apr 14, 2026 | 07:57 AM
Nottm_S2's Avatar
Above are good suggestions
Roof drain can overflow if part blocked, that usually affects arches though
Also condensation can be an issue, put a dry bag in there in winter
cat5cable
Jun 18, 2012 11:54 AM
Bassoctopus
Car Talk - Non S2000
21
Jul 21, 2009 11:23 AM
Moreno5
Oct 29, 2008 07:58 AM
terry_shum
May 8, 2008 01:21 PM
S2000RJ
Apr 6, 2007 12:55 PM
