Windscreen Washers
Old Jun 26, 2014 | 08:41 AM
richmc's Avatar
Originally Posted by Nick Graves
If your car is old, the pipes/NRV & stuff may be full of mildew and other stuff.
If they look black inside, rip the whole lot out & soak through on hot water.
You might have to run the pump with the reservoir filled with warm water a couple of times too, before it works properly.
Top tip - get some home brew cleaner/sterilizer that will kill the mildew and clean the crud out put a litre or so in the washer bottle, drive the car forward and backward a few feet with heavy braking to slosh it around.
As jsh said the jazz washers aren't colour coded, I've got a silverstone so black will go OK.
Old Jun 26, 2014 | 11:31 AM
Nick Graves's Avatar
Is Milton 2 safe on paint? It's a mild hypochlorite bleach.
But it sounds like a plan.
Old Jun 26, 2014 | 12:40 PM
s2k_Nut's Avatar
Why is it a fill up of this reservoir seems to last forever ? Mile after mile I think I may fill up the reservoir twice a year maybe!
Old Jun 26, 2014 | 12:58 PM
sound_wave's Avatar
Coz they are huge!!! Seriously!!
Old Jun 26, 2014 | 01:00 PM
WinFreak's Avatar
I think I've filled mine up twice in 20k miles.. the v50 used a gallon a week until I pulled the headlight washer fuse out of that one as well
Old Jun 26, 2014 | 01:57 PM
richmc's Avatar
Should be fine, just give it a good rinse down afterwards, at the very worst you may have to give the bonnet a coat of wax.
Old Jun 26, 2014 | 02:10 PM
rhauri's Avatar
I've had the same in two S2000's - both times it was the inline valves which sit just before the L bend leading to the jets (under the bonnet).
Can pick them up Halfords for less than a couple of quid each:
http://www.halfords.com/motoring/aut...e-valve-hfx370
Be careful though - I've bought a total of 4, and 2 of those didn't work, so a bit of trail and error may be in order (and keep the receipt if you need to swap em!)
Old Jun 26, 2014 | 11:54 PM
Toms1989's Avatar
If you have access to an airline, pull the hoses off from the washer jets and blow down them as they may have picked up dirt from the bottom of the washer tank.
Old Jun 30, 2014 | 02:21 AM
Electroblisio's Avatar
Thanks for all the advice.
Stripped down the hoses and the jets and gave them a good clean which seems to have sorted it out. The metal ball bearing at the end of the passenger hose was stuck in the closed position. I think this is something that will happen again so will just need to keep an eye on it!
Dhaval85
Jan 2, 2013 04:05 AM
Kris-S2k
Jan 16, 2012 09:00 AM
kmcknight2001uk
Oct 21, 2010 01:30 AM
andyhill24
Jul 4, 2009 12:10 PM
2HondaDave
Jun 20, 2009 01:30 PM
