17" track wheels
Old Oct 6, 2004 | 08:36 AM
Tedster's Avatar
That's the setup I've been using for 2 1/2 years, around 20 track days. Works great!
Two points to be aware of:
1) the width stagger front to back is not ideal, it moves you more toward oversteer compared to the OEM tires. You may need to compensate with alignment and/or bar settings. My car has always pushed, so it hasn't been a problem for me.
2) the fronts will rub on extreme suspension travel with steering input. My plastic fender liners are tucked above the metal now, after the tires erased some of the fasteners. Consider either doing that or rolling the fenders, or both.
Have fun!
Ted
Old Oct 6, 2004 | 12:20 PM
waltk88's Avatar
The RA-1 also comes in 205/50-17, which would match the 255/40-17 rear diameter. This combo might be a bit understeer biased.
Old Oct 6, 2004 | 02:28 PM
depletedUfoot's Avatar
I think you're right, Walt. That'd be close to OEM on the front, and much wider on the rear.
I'm curious, Tedster, how many track days do you get out of set?
Old Oct 6, 2004 | 06:12 PM
Tedster's Avatar
I got a lot out of my first set (maybe 15?), but some were pretty early track events for me (slow!) and some were rain days. I've done three (one of them rain) on the second set so far.
I got the second set shaved by Vilven to 6/32"; their normal shave depth is to 4/32", which leaves the shoulders pretty rounded off. The hardcore track people will tell you to shave to 4/32", but if you're an occasional recreational event person like me, I think you'll get more life out of them left deeper.
Old Oct 8, 2004 | 08:56 AM
stocky's Avatar
Here's a pic of 275 MXs vs. Stock S02s to give you an idea of the massive size difference:
Doesn't look like that much of a diffenrence considereing these are 225 vs. 275
OEm 225 S-O2 are very wide compared to other 225er's
Old Oct 18, 2004 | 07:29 PM
I'd call that a significant difference. Larger contact patch and higher gearing in one step. It's impressive that the S2K will accomodate that beast.
Old Oct 19, 2004 | 05:19 AM
Ajjra's Avatar
I'll vouch for the 225/45-17 255/40-17 configuration. I've been running them on Volk TE37's and love the balance. Have only had 4 track days on them so far but I don't feel a need to change sway bars. At worst, you may need to make a correction in steering to help compensate for lift.
wowwitsgau
Jan 24, 2014 09:46 AM
modMonkey
Jan 17, 2007 05:01 AM
blondie
Oct 23, 2004 05:21 AM
666devil
Apr 13, 2004 03:05 PM
00S2K01S4
Dec 10, 2002 12:37 PM
