another "will it fit" offset
Old Aug 2, 2005 | 12:02 AM
elude's Avatar
Default another "will it fit" offset
well looking around at wheel packages and came across a nice package from a-tech.
will this setup work?
front:
17x7, +43, 5-114.3 with 215/45/17
rear:
17x8, +42, 5-114.3 with 235/40/17
im currently running on Volk GT-N
front:
18x7.5, +49, 5-114.3 with 225/40/18
rear:
18x8.5, +49, 5-114.3 with 245/35/18
and currenty not rubbing. im lowered 2"+ with espelir springs and blown OEM shocks.. the current setup does not rub @ all, and runs great.
will the prospective setup match the setup i have know? any suggestions would be great! thanks..
Old Aug 2, 2005 | 07:41 AM
SIIK2NR's Avatar
Jon,
That set up will work but why?...... I'd get a better wheel that can accomodate more rubber all around....
Old Aug 2, 2005 | 07:44 AM
ASMspec's Avatar
Yes, that setup will work. I ran the Weds Sports SA90s and Black Racing wheels. Both have very similar offsets/sizes.
My BR wheels were:
+45 17x7.5 and I ran a 215/45/17 tire
+38 17x8.0 and I ran a 235/40/17 tire
My Weds Sports wheels:
+43 17x7.5 and I ran a 215/45/17 tire
+35 17x8.0 and I ran a 235/40/17 tire
Only down side with the Weds is it did rub in the rear. Strange how the BR wheels did not with only a 3 mm difference and same exact rear tire.
I was at or around a 2.5 inch drop with -2.6 camber in the rear. I was actually -3.6 before the accident.
Anyway that should work. For daily driving and commuting its fine. I agree with SIIKNR you want more rubber on the rears at least 245. With that said those wheels will rub if you slap on 245 rears.
Old Aug 2, 2005 | 01:24 PM
elude's Avatar
with that being said, i will rub with a 245 series,
but isnt the prospective setup still wider than stock 205 & 225?
i just do not want to get lower in wheel performance, than stock.
Old Aug 2, 2005 | 10:03 PM
SIIK2NR's Avatar
That's correct.... Just remember that the rear offset sucks by +20mm.
You can do better.....I know how you like to be lowered and this setup will not accomodate that at all...
jmardis
Apr 17, 2015 04:24 PM
jelanier
Jan 17, 2012 02:40 AM
adidas_man
Jan 30, 2011 02:45 AM
sho-one
Mar 21, 2010 05:59 AM
Fuelrush
Feb 13, 2007 11:50 PM
