AP2 05 S2000 Tire Selection Help!
Do the MPSS 245 tires fit the Volk 9" wide rear wheels well? It looks like they do on the data sheet at Tire Rack. I read a S2ki thread somewhere the other day where on poster suggested they look over stretched on the Volk 9" rear wheels.
I was boinking thru the trip odometer on my car yesterday and was shocked -- shocked I tell you -- to note I've put nearly 20,000 miles on the car in my 3 years of ownership! Only driven in the warm months. So much for my low-mileage 2006. She's pushing 60K miles now.
Went thru set of Bridgestone RE-11A tires. Running S-04 now (215/255). Car has no noticeable change in handling with the tire change. Still wonderful.
-- Chuck
-- Chuck
Hmmm. It must be how hard your miles are.
I just put on a set of s04 at the beginning of this season. April or something. I must have over 7k miles on them so far, and just looked at rears yesterday and no noticible wear yet. I'm sure if I pull out my tread gauge I could measure some wear, but point is they aren't anywhere close to half done. Tons of life left.
But my car is a 3 season dd. About 80 hwy commuting miles per day. I drive it like its meant to be driven, just not all the time. So a lot of the miles are easy miles.
Something to consider when considering the longevity reported by others here, how do their usage patterns compare to yours.
They're going to look a bit stretched for sure due to their sidewall construction. Either a very wide 245 or a normal 255 is your best option for your wheel width (if you want a squared off sidewall look) . But 245 MPSS will definitely work fine on a 9" wheel.
ONE complaint about the MPSS is that their on-center feel isn't as strong as other performance tyres...so they tend to kind of wander a little on road irregularities.
But...in terms of OVERALL performance, combined with everything else, it is pretty much impossible to find a performance tyre that is better than the MPSS.
I think the only way to root out a better tyre is to have a specific purpose in mind, and be ready to sacrifice in other categories.
After some more research/reading I decided to go with the new Continental Extremecontact Sport in 225/45 and 255/40 for these ce28s I have. I have them on the way.
I'm persuaded that these new Conti's will meet my needs performance wise and maybe they will last a little longer than some of the other options. Early reports re performance are very positive and put them essentially on a par with the Michelin tires.
Typically 215/255 is result of a misguided attempt to emulate the CR sizing. Trouble is the oem cr 255 rear is actually closer to a 245 in any other tire. If you want cr stagger f/r balance, unless you are going to use RE070 (and who would today), IMO you should use 215/245.
Or like poster a couple replies above, upsize both ends to 225/255.
