Is this a problem?
Old May 11, 2009 | 06:21 AM
Thomas Guide's Avatar
Default Is this a problem?
Hey all, just got new Yoko AD08's, will be mounting them this week. Upon closer inspection, I noticed a small tear in the side of the side block. This is far enough down where it will not make contact with the pavement.
I know that when you get a nail in the sidewall they won't repair it, am concerned this is similar.
Any thoughts if this is a potential problem?
Old May 11, 2009 | 06:55 AM
TubeDriver's Avatar
*I am not a tire engineer*
That cut *appears* to be located on the side of the tread block so there should be plenty of rubber in that area. My opinion is that the tire will probably be fine but I would certainly keep an eye on the cut to make sure it does not cause any issues down the line. I have run r-comps that get small tears and cuts from rocks and so forth (about the size of your cut), it has never been an issue.
That being said, if you want to be 100% sure, replace the tire.
Old May 11, 2009 | 08:05 AM
EOE's Avatar
EOE
Dude... Really? You are fine.
Old May 11, 2009 | 09:44 AM
I'm just being paranoid. Some people say take it back, why take the chance of a problem at 90 mph... others say they ride with those all the time...
Can it start to rip more on hard turns?
I'm thinking I'll have them replace it out of piece of mind.
Old May 11, 2009 | 10:21 AM
EOE's Avatar
EOE
If they willing to do it. Then it won't hurt. As long as it makes YOU feel better/safer.
I would roll with it and don't find it a big deal. Others might.
TRD_Celica
Jan 8, 2011 11:46 AM
Fusiondynamics
Mar 14, 2010 07:46 PM
C6400hp
Nov 8, 2005 02:13 PM
ElTianti
Aug 10, 2005 04:31 AM
soundzero
Mar 11, 2005 05:35 PM
