Which tire?
Old Jan 17, 2005 | 05:38 AM
s2000_19's Avatar
Default Which tire?
SIZE: -- 18 x 7.5
LUG PATTERN: -- 5 x 100/114.3
OFFSET: -- 48
These are the numbers of the rims i just purchased can someone tell me what tired numbers will be best for my s2000.
Thanks
Justin!
Old Jan 17, 2005 | 12:00 PM
Batbite's Avatar
Did you buy the same wheel sizes the front and the rear...........?
Old Jan 17, 2005 | 12:18 PM
s2000_19's Avatar
yea i did. can you tell me what tire i should purchase?
Old Jan 17, 2005 | 01:10 PM
Batbite's Avatar
That is very very difficult...........Especially if you are concerned with the car's cornering performance & stability.
The S2000 has a staggered front to rear tire & wheel size.........Honda set the car up that way to account for the car's tendancy to want to "overstear"......to be tail happy when cornering.
1. It would have been best if you had / can buy or exchange for a wider wheel in the rear......such as an 8.5" or 9" width for example.....this would allow for easier / better tire fitment to achieve the correct stagger.
Note: If you change to a wider rear wheel you need to get a higher offset so you do not have rubbing / clearance issues..... 8.5" a +55 min........9" +62 / +63 would be great.
The offset of +48 is OK for the front for a 7.5" wide wheel.........but as I mentioned above it makes it hard to fit for the rear tire......and still maintain a stagger
2. The OEM diameter on the front wheels with Bridgestone SO-2's are 25.0"..............and 24.8" in the rear. The closest tire sizes to this that will correctly fit your wheels are:
215/45/18 = approx 25.7" diameter
225/40/18 = approx 25.0" diameter
Exact diameter per size varies slightly from tire to tire manufacturer to manufacturer.....but it is important for the ABS (anti lock brakes) as well as for the gear ratio and spedometer.
3. As far as just putting a wider tire on the 7.5" wheel in the back............it is possible to get a 235/40/18 on the 7.5" wheel but that's pushing it & I'm not sure about clearance / rubbing in the rear......that size tire & up is recommended to have 8" wide wheels and so on.....
4. If you can not exchange or swap....and are stuck with exactly what you have I guess I woulds say:
215/45/18 - Front
235/40/18 - Rear
They are similar in rolling diameter.........will not change / affect the gearing / spedometer much...........front will have no clearance issues........No Guarentee in the rear.
Old Jan 18, 2005 | 05:34 AM
s2000_19's Avatar
i really appriciate all u writing them all up for me as i am going to have to keep these cant afford to get rid of them right now cause i just bought them. i am a lil unsure about this because of the fact thatu say it would be pushing it to put a 40 on a 7.5 ? so should i go and get those tire numbers ? and wouldn't it look weired with 215 and 235 different? plesae get back to me asap.
Thanks
Justin!
Old Jan 19, 2005 | 05:27 AM
s2000_19's Avatar
could i get away with buying 4 225/40/18 and puttin them on?
Old Jan 19, 2005 | 11:50 AM
Jim@tirerack's Avatar
Former Sponsor
That is the only size to run on the wheels you purchased. Like batbite said the handling would suffer by running the same width tire and wheel on front and rear.
clarkster009
Aug 18, 2010 11:15 AM
dunsstop
May 16, 2006 07:36 AM
darkfx
Feb 13, 2006 06:34 PM
bs-inc.s2k
May 4, 2005 02:53 PM
04RioS2k
Jan 15, 2005 08:33 PM
