Wheel Fitment Guide
Old Jun 14, 2013 | 06:05 AM
  #731
devezina108's Avatar
Good day,
I am a new S2000 owner and I need help. Car is 2002. I would like to by new mag & tire. I would like to go with the 17 inches. This is what I am looking for
Rota DPT - Flat Black (5x100/114.3/e48F/e42R/73)
Product Details:
Wheel Style - Rota DPT
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - front 8/ rear 9"
PCD Bolt Pattern - 5x100/114.3 (dual drill)
Offset - +48F, +42R mm
Hub Bore - 73mm
Color - Flat Black
Since I don't want to do any mod on my car. Is the rear setup will fit without any modification. Thanks in advance for the answer. Really appreciated.
Denis
Old Jun 16, 2013 | 06:20 PM
  #732
v10killer's Avatar
im lowered on tein s-spec and finding a wheel that would fit is the hardest thing anyone no of a few good sites trying to avoid rolling my fenders if possibe want to run 225/40-17 all around on a non staggered setup what do you guys think will i have problems with a +45 offset
Old Jun 18, 2013 | 11:22 AM
  #733
v10killer's Avatar
17x9.5 +60 fit in the front with a 255 lowered on teins and koni yellows
Old Jun 18, 2013 | 11:23 AM
  #734
v10killer's Avatar
sorry 17x9 +60
Old Jun 18, 2013 | 01:09 PM
  #735
Manga_Spawn's Avatar
Site Moderator
Originally Posted by arsenal
Rather than create a new thread, does anyone have wheels in the following fitment:
17x8.0 +32 in front
17x9.0 +38 in rear
Would like to know kind of soon, Blitz Type 01 CX
Thanks
Doable. Roll fenders, relocate tabs and get an alignment. Probably going to need about 2-2.5 degrees all the way around.
Originally Posted by devezina108
Good day,
Product Details:
Hub Bore - 73mm
Color - Flat Black
Denis
Same as above. You will need to roll the fenders all the way around though you can probably get away with stockish camber.
Old Jun 18, 2013 | 01:14 PM
  #736
Site Moderator
sorry 17x9 +60
Ok So you are wanting to run 17x9 +60 all the way around? Rears should be no problem with a 245/40/17 and you shouldn't need a roll. You may need a little more camber but not much. Fronts will be an issue no matter what. The issue with the fronts is since the wheel turns the fender lip can be grabbed even by a stock wheel. Since you are lowered the problem is even worse since there is less gab between the top of the tire and the fender. It is when you are turning out of a driveway or something like it where it can be a real problem. If you roll the fronts you could easily run a 245 in the front as well.
Old Jul 9, 2013 | 09:24 AM
  #737
S2Krazy89's Avatar
I want to run 255/40/17 rears on 17x9 +45 or +49. I don't want to pull but rolling the lip and relocating the tab is fine. Currently running -1.5 camber in the rear. Will these fit without messing with the camber? Lowered about 1."
Old Jul 9, 2013 | 09:43 AM
  #738
1nate7's Avatar
Yes, that will work with a roll and tab relocation. No additional negative camber or fender pull necessary.
Old Aug 8, 2013 | 08:22 AM
  #739
vr0om's Avatar
Looking at some volks evo 4
Front 17x8 +40
Rear 17x9 +40
I am lowered on eibach pro kit on koni yellow's lower perch, what kind of mods are needed to get these to fit?
thanks
Old Aug 8, 2013 | 08:51 AM
  #740
Site Moderator
Roll fenders, relo tab and alignment.
