Wheel Fitment Guide
Old Mar 9, 2011 | 07:05 AM
  #631
roc_sky's Avatar
Im lowered on Espiler Springs..
And I want to make sure that they're ok, or I do need to roll my finders.
RPF-1's 17x9 45 offset all 4, and 245/40/17, 255/40/17.
Thanks
Old Mar 10, 2011 | 01:09 PM
  #632
feistyS2K's Avatar
I'm lazy and don't want to read page by page....
who's the current contact at Tire Rack for us s2ki folk?
~mary
Old Mar 25, 2011 | 10:42 AM
  #633
kulo's Avatar
will these sit flush/rub?
Old Mar 26, 2011 | 01:26 AM
  #634
panda express's Avatar
hi guys i understand this guide just fine, though it seems there is an in-between range that seems needs better explaining
ex. Front fit
rims size 17x7.5 +45mm >>>> recommended tires (205s), while 205 tires land within +45mm offset regulation, is 7.5" width not at the edge of the 205 tire recommendation?
IF this is the case would 215s be a safe replacement even though the guide say +48mm is recommended? As it seems 205s are better for the rims offset, while 215s are better for the rims width. So the question is, which tire size is correct/best?
Old Mar 28, 2011 | 06:17 AM
  #635
xthumper32x's Avatar
Just wondering if some 17*8 +37 will fit. I had these on my RSX-S and I really don't want to get rid of them. I can't remember off the top of my head but I think the tires on them are 225/45. they are in storage right now because I didn't use them in the winter.
Old Apr 17, 2011 | 12:53 PM
  #636
insulin's Avatar
Hi, guys.
I want to change wheels on my ap1 16 'to 18'.
The dimensions of the four wheels are: ET50, 8J 18
I want to mount four equal size tires 225 40 18
Everything will be okay?
Old Apr 17, 2011 | 04:28 PM
  #637
dwight's Avatar
' = foot
" = inch
Old Apr 21, 2011 | 07:50 PM
  #638
NS_S2K's Avatar
Got the wheels on today, 18x8 +45 245/40/18 all around...the front only rubs when i go over a bump... i'm gonna get all the fenders rolled on sat just in case..i already set up an appointment....i'm gonna raise the front coilover up a bit and see if that fixes the rubbing issue...the rears are perfect!
Old Apr 25, 2011 | 04:44 PM
  #639
itlynstalyn's Avatar
Need some help.
Tires are getting bald and want to run the widest tire possible without making it look retarded in the rear. I have a turbo kit, so the more traction, the better.
Wheel sizes are 17X8 +40 in the front and 17x9 +45 in the rear. Not lowered at all on stock suspension. Is a 255 on the front and 275's on the rear out of the question, or ridiculous?
Any help would be appreciated.
Old Apr 28, 2011 | 03:02 PM
  #640
insulin's Avatar
I want to buy wheels 18 inches in size 8J, ET50. Will I have a problem because I want to change the suspension.
What tires should I put in order not to rely.
For the front I stopped at 225/40 and 245/35 for the rear
Do you think there will be a problem with these tires, if the car has lowering springs
HELP ME !
