Wheel and tire question.
Old Jan 9, 2012 | 05:53 PM
straightWORK!'s Avatar
Default Wheel and tire question.
Looking into buying a set of buddies ap2 v1's. He has 4 rears and 2 fronts. Don't really know which one to do.
Staggered with a 235/40 & 255/40
Or
Square with 255/40's all around
Thanks.
Old Jan 9, 2012 | 09:26 PM
dc2-2-ap1's Avatar
If you can go non staggered then do that. The center bore has to be machined to fit though. These are not exact specs but the front bore is around 70-71mm while the rear is around 68mm. I can't say for certain if 255's will fit up front on this setup. I think it would require some work to the fenders and possibly a spacer. I am drawing a blank about the specs right now. But if you do the non staggered setup you might want to replace your front sway bar.
After looking at the rear specs you should be fine without spacers or a roll
Old Jan 10, 2012 | 03:49 AM
Mar48's Avatar
I would go with the square setup, you can find a machine shop to bore out the rears a little. Shouldn't cost much.
Old Jan 10, 2012 | 04:05 AM
CoolGuy094's Avatar
If you autocross or plan on autocrossing, then I would say square setup with the supporting mods (sway bar). If you just street it, then I would say go staggered. I have a staggered set of AP1's for the street and a square AP2V1 setup for autox.
moefosho
Sep 7, 2017 08:11 AM
Brndon
Apr 19, 2013 01:14 PM
124Spider
Feb 15, 2011 01:28 PM
SPECIAL-OPS-S2K
May 10, 2008 11:09 PM
agent
Dec 21, 2007 01:15 PM
