widest tires for 7" wide rims
Depends on aspect ratio.
I *might* go as wide as 245's with a 45 aspect ratio, 225's in a 40 aspect ratio.
Are these wheels on the front or the rear or all around? Stock AP1 rears are 7.5", good for 245/45-16's easy.
Check the tire manufacturer's rim width requirements for the particular tire you're considering.
Probably better off tracking it on the stock wheels. 225s up front and 245s in back is likely your best bet for maximum grip. Tire selection is more important than size, though.
Quick Question. I was getting opinions as well about running 225/50/16 Front / 255/40/16 Rear on stock AP1 rims. Some told me it was fine while others say huge risk. If there is a risk of running the rim off the tire, then I will lean towards no on this tire size.
Where are you finding a 255/40-16 tire?
Probably too wide on a 7.5" rim, what does the tire manufacturer give as minimum recommended rim width?
Also quite a bit smaller in diameter than stock.
