Post your Catch Can Setups
Old May 18, 2009 | 11:49 AM
siadam's Avatar
Default Post your Catch Can Setups
On my 99 Si, I had two -12an bungs welded into the valve cover to vent crankcase pressures. I thought the s2k (my ignorance) would be ok, as we already have 2 bungs, albeit smaller, I figured it would suffice.
Well, after a few pulls, I'm seeing my dipstick pop up a little..so I know I'm exceeding the limit of the factory system.
I've already got a small air filter on the first bung off the valve cover, and a tiny can on the 2nd one, closest to the firewall open to atmosphere.
I was thinking of pulling the pvc valve and hooking it up directly.
Thoughts?
Old May 18, 2009 | 12:13 PM
kutsujula's Avatar
I have 3 bungs welded on mine.
Old May 18, 2009 | 12:44 PM
Ness2000's Avatar
Pics of this please!
Old May 18, 2009 | 01:12 PM
AndyFloyd's Avatar
A quick fix for the dipstick is to turn it around 180* and that will keep it from popping out. But youre right, the real issue is crankcase pressure. Kutsujula had a T1 race parts setup that was real nice, like he said 3 bungs off the valve cover. I want something that will work but isnt real huge.
Old May 18, 2009 | 03:26 PM
300sx's Avatar
Here's my setup I threw together. Going to make a nicer one sometime down the road...
Old May 18, 2009 | 03:35 PM
Slows2k's Avatar
Old May 18, 2009 | 03:53 PM
Boofster's Avatar
That looks nice!
I went with this from ATP Turbo.
Routed both valve cover hoses to it. No IM return.
Old May 18, 2009 | 03:56 PM
KewlWhip's Avatar
Oil catch can / coolant reservoir combo
asukadc's Avatar
dual can setup, 2nd catch can ordered, will replace this one,
Old May 18, 2009 | 03:57 PM
Slows2k's Avatar
Mine isn't vented because it's used as a oil separator on the PCV line. It was made from a A/C drier on a 96 Odyssey.
