Blown diff/axle?
Sounds like the diff to me. Typically the ring and pinion gear teeth sheer off as the typical failure on ap1 diffs because the end caps on the carrier bearing flex over hard use and this pulls the ring and pinion gear out of alignment and then they sheer. The end caps on the ap2 diff are beefier. If you have a tooth sheered off, its possible the diff could still be functional but would cause some noises. Ive blown 2 ap1 diffs and both essentially gave me little/no warning before they just let go completely.
Have you drained the diff oil to look for gear/metal chunks? Be first on my list before replacing anything.
If its clearly coming from a particular side, then you have a bearing/hub and brake system to inspect.
We have to get our terminology right before there is any chance at depicting where the issue is. I know there is a half dozen terms for the same thing regarding these parts.
Some small shavings are normal on the magnet drain plug in diff btw. If you have a giant gob/stack of actual individual shavings you can see rather then just a "goo" there may still be an issue there. But only a pic could really tell us who have a trained eye.
Something you can do IF im understanding your troubleshooting reference, is unbolt the main long driveline, and then turn the wheels and see if that isolates the noise/clunking. If the sound goes away, then you know its the driveline or trans. You can look at each end of the driveline joints for signs of metal shavings, or red powder, anything that gives away a failed bearing/joint.
You mean the main driveline/shaft? Or the other half shaft/axle you didn't replace?
TrackStar
12-09-2004 09:03 AM
