Engine burning oil in vtec
Old Feb 26, 2005 | 06:00 AM
jakestephenitch's Avatar
Default Engine burning oil in vtec
My other car, a del sol with a B18c started burning oil really only when in vtec. It has good compression in all cylinders approx 230psi. I probably need to get a leakdown test, but I thought someone else may have experienced this. The engine has about 70k miles on it. Im guessing valve guides? or something. Any comments are appreciated.
Old Feb 26, 2005 | 06:15 AM
Slows2k's Avatar
It could be the worn guides, or stuck oil rings. A leakdown will help determine the problem.
B18's are cheap enough I'd buy another used engine and rebuild your current one. Look for a JDM Automatic B18C, they don't spin as many revs as the 5spd's.
Since this is about a Del Sol, Moving to Car talk as well.
Old Feb 26, 2005 | 09:56 AM
aklucsarits's Avatar
How much oil are you talking? Pretty much ALL VTECs consume oil at high rpm. 1qt in between oil changes is pretty normal if you are frequently at high rpms. A good percentage of that oil is typically lost via the crankcase ventilation tube.
Andrew
Old Feb 26, 2005 | 06:28 PM
Xeneize12
Guest
Posts: n/a
this sounds right...
but I wouldn't buy an entire new B18C if the only problem is worn guides...just rebuild the head...
Old Feb 26, 2005 | 06:29 PM
Xeneize12
Guest
Posts: n/a
Andrew
right
mk84
Apr 21, 2008 10:10 AM
Xiao Li
13
Sep 13, 2005 10:47 PM
RazorV3
Mar 25, 2004 12:52 AM
FormulaRX
Dec 26, 2003 07:57 AM
gtolot
Dec 13, 2003 12:56 AM
