new question! just got my s2000!
Old Jan 16, 2007 | 11:49 PM
Gerald28's Avatar
Default new question! just got my s2000!
i just brought my car home today and as i lowered the top i realized the glass window was stopping the top from fully going down. what do i do to fix this?
Old Jan 17, 2007 | 02:06 AM
Jamie_Murray's Avatar
Just a question. But did you buy your car from Kentucky? Because the steering wheel looks crooked like the once i test drove here.
Old Jan 17, 2007 | 03:35 PM
NDAZONE's Avatar
Replace your top with one that has a plastic window!
Old Jan 17, 2007 | 03:44 PM
FISH22's Avatar
your car is fine!!! if its sorta cold out, the top will do this. my 03 did this, and so does my 06
Old Jan 17, 2007 | 04:03 PM
CobraTi's Avatar
Might not be the window but the elastic straps that help lower the roof correctly. Looking at your tach, you have an AP1 so its possible the straps just dont pull one of the top bars enough because they're a few years old.
Old Jan 17, 2007 | 04:32 PM
ian05s2k's Avatar
just the cold as said above, mine did this from time to time before i put it away for the winter.
-Ian
Old Jan 17, 2007 | 08:13 PM
hk_s2k's Avatar
^^same here, just keep trying until it goes all the way down. you can also push on it a little to get it all the way down.
Old Jan 18, 2007 | 05:52 AM
Chazmo's Avatar
My MY02 has a bar that slides forward from right above the rear window (when up) when you lower the top.
In cold weather, this bar doesn't move readily, and actually can wear holes in the top. Lower the top a little, and grab the bar and slide it forward, easing the top material behind it.
That seems to work for me.
BTW, top operation is not recommended below 40 degrees or so. Precisely because the material gets less flexible and can tear. That, of course, doesn't stop me through the winter here, though.
MercGuy
Aug 23, 2016 06:19 PM
acklavidian
Aug 9, 2016 11:07 AM
W0Pdego
Sep 5, 2011 10:54 AM
REVZ TO9
Apr 30, 2007 07:25 PM
mrmumbels
Nov 26, 2005 05:44 PM
