NA: ITB's
Yah, what I'm dealing with is pretty similar to what you see when you stomp on it at idle. But for me, its not just idle, its any time TPS is less than 10%.
What kind of accel fuel settings are you using for your tune?
You're using AEM right?
Hypothetically speaking...
I were to order the Jenvey kit from Fuji Racing tomorrow and AEM EMS, what else would I need to get my car running?
I understand I need parts for the fuel system since thats the one area troubling me with this potential install.
isn't jimmy giving you the fuel rail and FPR? if so, all you need is to modify the oem fuel lines.... cut the banjo and replace with a coupler to extend the hose to the FPR (depends where you mount it) for both supply and return.
i dont know if you ordered injectors from him too, if not then RC injectors are fine.
good luck.
good luck.
good luck.
good luck.
Jimmy includes everything else (fuel pressure regulator, vacuum can, fuel pressure gauge, map sensor hook up...)
Originally Posted by alejo,Apr 7 2008, 10:06 AM
oh and any type of filtering system, although the kit comes with the standard jenvey foam housing it does not fit under the hood of the S
Does Fuji supply the vacuum block, or ill need to get that on my own also?
What do you mean buy cutting the horns?
Did Steve PM you yet? I referred him to you.
Originally Posted by Francesco,Apr 7 2008, 08:10 AM
Where did you get those filters you were using?
Yes Fuji provides the vacuum block.
The ideal size horns run into eachother because our engine is small/cylinders too close so you have to actually cut the horns to fit.
Got his PM thanks.
Originally Posted by Francesco,Apr 7 2008, 06:22 AM
I havnt ordered anything yet, I just want to make sure I know all that I will need.
also when you order the kit, it comes with the jenvey foam filter which doesnt fit... he does have a screen filter though to filter big particles.... it goes in between the tb and the horns, i have em.
