Tuning for high elevation?
Old Jan 25, 2015 | 10:23 AM
jjost15's Avatar
Default Tuning for high elevation?
Hey everybody, I just brought my S2000 from Chicago to Colorado with me. To obviously the lack of oxygen is coming into play. Since I've been here the car has died at a red light 3 times and just kind of lags coming out of first gear and the idle is pretty low sometimes. The ECU has adjusted a little bit but V-tec doesn't seem to hit as hard as it used to. Can anyone shed some light on what my options are. Except forced induction, not quite in the budget. It has a short ram intake right now, I'm thinking a cold air might help a little bit. But I've been out of the mechanic game for a few years now so I'm running dry on ideas. Thanks
Old Jan 25, 2015 | 01:46 PM
Chuck S's Avatar
Tried resetting the ECU? Disconnect the battery. (Be sure find the radio code first.)
I bought mine last summer and I found out these cars needs lots of engine rpm. 4300 is the shift point 1 to 2, etc.
-- Chuck
Old Jan 25, 2015 | 04:19 PM
sillyboybmxer's Avatar
search for "map wack" and try that out
Old Jan 26, 2015 | 04:07 PM
jjost15's Avatar
Thanks for the help guys i'm gonna check it out this weekend. along with brakes and oil change. Seafoam helped alot by the way it runs alot smoother now. I'll check out the MAP Sensor later.
S2000 TypeSS
Nov 24, 2020 10:54 AM
Itchy Dick
Mar 19, 2011 01:59 AM
Welshman
Nov 8, 2006 05:52 AM
jdmgpw04
Jan 29, 2006 11:52 AM
mr_ninobrown
Dec 20, 2005 05:23 AM
