Alarm Installation
Old Aug 19, 2008 | 07:34 AM
HankookS2K's Avatar
Originally Posted by Stealth_SUX_,Aug 18 2008, 07:34 PM
The locks actually require two five wire modules if you dont use that two wire method..
Also there right about DEI voiding your warrenty if you dont have a pro install it.
But im a mecp professional and had no problems with them so far.. not to brag any lol
two five wire modules? ive never done that on an s2k. i think your doing more work than required.
Old Aug 19, 2008 | 09:11 AM
Stealth_SUX_'s Avatar
[QUOTE=HankookS2K,Aug 19 2008, 07:34 AM] two five wire modules? ive never done that on an s2k. i think your doing more work than required.
Old Aug 21, 2008 | 11:11 AM
wisdom's Avatar
Bump for more info.
How would you know when to wire a relay?
Old Aug 21, 2008 | 02:22 PM
HankookS2K's Avatar
Originally Posted by wisdom,Aug 21 2008, 12:11 PM
Bump for more info.
when you look up your cars wiring diagram it will tell you if you will use a 2 wire or 5 wire system
Old Aug 21, 2008 | 03:46 PM
wisdom's Avatar
Hmm... wiring diagram as in which color wire has which function. For example white wire is a constant 12v wire.
Care to elaborate?
Old Aug 21, 2008 | 07:21 PM
chairmnofthboard's Avatar
Oh man there are tons of wires. I think I'll leave it to a PRO so I can keep my warranty.
Old Sep 2, 2008 | 08:59 PM
I had a local shop do my S14 as a tester. They did a horrible job, I mean the alarm works, but the workmanship is CRAP. I guess I'm going to do the alarm on the S myself.
What happened to people, does nobody besides me take pride in their work anymore?
Old Sep 3, 2008 | 06:56 AM
S2K2XGA's Avatar
KARR Alarm does excelent work, very clean.
Old Sep 3, 2008 | 06:40 PM
mrpoopiehead's Avatar
I'm installing a Viper 791XV right now, and its not too bad. Most of the wiring that you need is located at the keyless entry module, and ignition is pretty easy to wire as well.
Old May 7, 2010 | 08:25 AM
s2kflorida's Avatar
Ok so I can't find my answer anywhere and you guys seem to know.
I have a Viper 350 Plus system and it has a 2wire system. One wire (blue) is (+ Lock) and (-Unlock). The other wire (red) is (-Lock) and (+Unlock).
I see the S2000 wiring info says Power Door Lock is Pink/Black and Power Door Unlock is Pink/Blue.
Can someone draw me a diagram?
ChadS2k1985
Apr 25, 2017 03:32 AM
SlowTeg
Nov 3, 2010 12:16 PM
topless!
Mar 7, 2008 12:23 PM
ninjay2
Aug 25, 2007 06:54 AM
s24me
Nov 10, 2004 01:54 PM
