Alternator Hummmmmmm
Old May 30, 2007 | 11:43 AM
  #21
O-turn's Avatar
Well:
Chris, I did not have the whine before taking to the shop...
No body work was done up front, rear fender and bumper, as well as a new trunk lid were installed...
I shortened the ground wire to under 1'-6", and sanded the ground area down some more and the whine comes and goes, drives me nuts, I bought a ground loop isolator and have yet to install. I will try making sure the battery is tight.
Old May 30, 2007 | 11:50 AM
  #22
oth's Avatar
oth
I'd look for an alternate source of EMI - I had a similar problem
when the tech forgot to tighten something down, causing a wire to
rub against the alternator pulley. Lots of noise until the wire was
cut. Is the noise coming from all speakers?
Old May 30, 2007 | 04:02 PM
  #23
jwa4378's Avatar
If it definitively came after the body shop, it sounds like a grounding issue. Have you found any other ground around that area (not just shortening the cable, but a whole other bolt)?
John
Old Jun 1, 2007 | 08:28 AM
  #24
O-turn's Avatar
John
There isnt really anywhere else to ground in the trunk other than that one spot thats pictured above...
All my wiring in the engine bay runs through the wiper cowl...
Old Jun 1, 2007 | 04:29 PM
  #25
jwa4378's Avatar
You should be able to ground to the old spare tire anchor thread... You will need a different bolt, so it fits flush when tightened, instead of the exposed wing-nut on the old one. You can attach the grounding wire, then put the amp rack (assuming its a spare-tire area rack) over the ground when its installed.
There should be a few areas around there to ground (one is over the gas tank area... shady for a ground spot and I think there is another a foot or two toward the front of where you are grounded now to the metal reinforcement that is RIGHT behind the rear trim panel on the passenger's side)... I will see if I cant take a few pics this weekend.
John
Old Jun 4, 2007 | 05:49 AM
  #26
O-turn's Avatar
John
I really appreciate your help. I will try that bolt this week and let you know what happens, my only concern there is I re-used my spare tire bolt to hold the amp rack in place. Ill need another way to anchor it, but I can worry about that later.
Yes, please take pics of the other spot if you get a chance!
Brian
Old Jun 7, 2007 | 04:12 AM
  #27
O-turn's Avatar
Update 6/7
I tried re-grounding to the spare tire thread, still there. I then tried the Ground Loop Isolator I bought, did not work.
Is it possible overspray got into my crossovers and f-ed them up? There is a fair amount on the outside casing and there are maybe 1/4 holes all across the top....
Old Jun 7, 2007 | 12:03 PM
  #28
S2KinVA's Avatar
Are you running XM or Sirius?
Old Jun 7, 2007 | 12:13 PM
  #29
O-turn's Avatar
Neg, Ipod only
enginestoppy
Jan 21, 2011 06:09 PM
cat7
Jul 17, 2010 09:41 PM
AdrianG
Aug 31, 2005 12:46 AM
moc8
Nov 1, 2002 09:36 PM
MDS2K
Mar 27, 2001 07:44 PM
