Amp power wire
Old May 16, 2004 | 08:24 PM
Darien1629's Avatar
Default Amp power wire
I just need to know where is the best place to bring the amp power wire into the car from the battery?
Old May 17, 2004 | 08:06 AM
PJK3's Avatar
remove the battery and you'll find a rubber grommet that works perfectly.
if you do a couple searches, you'll find dozens of threads on this issue. many of them have detailed photos and instructions. also, check the S2000 Electronics FAQ.
Old May 17, 2004 | 11:34 AM
Darien1629's Avatar
thanks
Old May 17, 2004 | 02:41 PM
dut's Avatar
dut
- off topic.. im going to run my nitrous line pretty soon.. does the driver side also have a grommet to the engine bay?
Old May 18, 2004 | 05:38 AM
PJK3's Avatar
honestly, there various grommets all over... but i'm not sure if there is a specific one that mirrors the passenger side grommet that is so commonly used for amp wiring...
Old May 18, 2004 | 08:28 AM
chrissa's Avatar
There is a major grommet that has a fat bundle of wires running through the firewall on the driver's side. It almost mirrors the one on the passenger side. The driver's side is right behind the clutch reservoir. It looks like a tight fit and is way up under the dash, but you'd get a stock look if you could squeeze the line through there. Is the line a steel braided hose or a hard line like a brake line?
Chris.
Old May 18, 2004 | 11:36 AM
dut's Avatar
dut
[QUOTE]Originally posted by chrissa
Old May 18, 2004 | 11:37 AM
dut's Avatar
dut
- I will check it out once im ready.. thanks again..
Chad!
Jul 21, 2010 04:03 AM
Crackerballer
May 19, 2009 12:52 PM
s2krey
May 9, 2008 02:10 PM
Bass
Mar 23, 2005 05:52 AM
Scanman
May 12, 2004 10:03 PM
