Android Single Din w/o Cutting!
I already have an ODB2 adapter ($10 on Amazon) so I don't need that. There is a TPMS add on available but since I don't have the sending units on my tires I'm not going to bother with that either,
I am however getting the backup camera. And I THINK this is the harness. https://www.joyingauto.com/honda-and...t-harness.html
Hmmm. There are two versions, the -1 and the -2. Now I'm not sure which to get. Looks from the URL like the -1 version supports 5Ghz wifi. Although both have the 5Ghz icon.
I can't tell what the difference is. I compared the specs side by side using the compare function and they are the same.
https://www.joyingauto.com/joying-an...5ghz-wifi.html
https://www.joyingauto.com/joying-8-...-internet.html
Update: I think the -2 is just a newer interface.
Note that the install posts are for the JY-HOS01N4GS-2, which is no longer available. Newer one is the JY-HQS01N4G-1 or JY-HQS01N4G-2. Near as I can tell the only difference is that the old one is Android 8.1/Intel and the two newer ones are Android 10/Octa-Core (same speed). The -2 version has a "new interface" but they don't show enough of it to tell which is better.
This all looks so good, I’m so impressed with the install and those ball mounts look epic in functionality. It’s a great upgrade although I don’t fancy paying for a sim, simple apple car play will do it for me. It’s going to be a Christmas project, that with 4 component speakers and a fair bit of sound deafening, I think it will be a decent upgrade.
Do you think it’s worth adding the amps to power the speakers then and not use the headunit itself? Where do you stow this amp? I wasn’t planning on adding one in but if it’s essential I might do.
FYI, i contacted Joying and this is NOT the correct harness. They do not sell the correct one, you have to get it yourself.
Anyone know what's the correct harness to get?
see below
If you're talking about the adapter harness that plugs into the car's radio harness you want something like
the . Note that originally this harness did not have pins/wires for the s2000-specific dash and
mute switch wires, though newer versions probably do since Metra sells dash control interfaces.
the Metra 70-1721 . Note that originally this harness did not have pins/wires for the s2000-specific dash and
Toecheese, get that harness.
yep, this looks like what I need, thanks. Doing it myself, BTW.
