AP1 Sound System problems
thanks buddy
so inow i dont need to buy a monoblock ???
im going to disconnect the sub first and then run it into 1 channel and leave one spar ... does that sound right ?
also i heard that there is something called flashtac which is 30 bux for 10m at bunning which is justy like dynamat... heard of it ??
basically i remove all trims for the boot dynamat it ...?
what about the boot lid ?
that seems to be the cause of it all ???
well if you want to run the sub on the current amp you require 4 ohms. I'm not sure if you can run just off one channel, i'm not sure that anyone really does that. If you require a sub most ppl either bridge a couple of channels with the correct ohms and it will work, or get a seperate monoblock. bridged doesnt seem to work as it creates 2 ohm on your current amp. you can give it a try on one channel but as i said even if it works, 65W RMS to a sub is jack shit. its not going to be like 65W RMS on your splits. try it anyways.
"With your current schneider amp you can run teh splits off two channels, but the sub can only run off one of the channels, meaning you will run 65W RMS @ 4 Ohm into the sub. it will work."
i dont know what you mean exactly?
or would i be able to run the negative to one channel and the positive to the other over 2 channels?
hey guys
you guys were right !!
the amp wasnt powerignt he sub enough so it was cutting out...
ive just bought a precision response 800w RMS mono block to power up the sub and it goes very well ..
thanks agin guys
thanks agin guys
