Can the S2000 be programmed so horn will
Old May 30, 2006 | 07:49 PM
BrianTucson's Avatar
Reach up under the dash, right behind the start button. Find the Gray plug which is facing upward. Thats the plug which is plugged into the RKE module. Cut the orange wire. You will never hear the horn again when you press the remote 2 times, nor will it go off when you hit the panic buton. The horn will still work when you hit the horn button on the steering wheel.
OR:
Just hit the lock button once on the remote. Same effect.
Old May 30, 2006 | 11:08 PM
iam7head's Avatar
OR:
Great info, i am not cutting anything but you know your wires
Old May 31, 2006 | 10:53 AM
r_duff's Avatar
OP, if your keyfob has a panic button, you can hold down the lock and unlock buttons for 5 secs and it will toggle beep/nobeep modes. if you dont have a panic button, then just push lock once.
Old May 31, 2006 | 01:13 PM
Quivers's Avatar
Banned
Just tap into that wire and add a siren, real easy.
pick any siren youd like.
Old May 31, 2006 | 05:28 PM
Only as long as you add a relay. That wire is the horn relay actuator ground.
jimbo69ny
Jun 27, 2013 04:34 AM
s2jeezy
Feb 6, 2009 02:17 PM
WPS
May 14, 2004 02:39 PM
FormerH22a4
Jul 20, 2002 08:33 AM
SomethingWicked
Dec 28, 2000 10:07 PM
