disable auto door lock function
Old Feb 6, 2009 | 09:22 AM
s2jeezy's Avatar
Default disable auto door lock function
hey guys i have a clifford 50.5x alarm on my car and it has the auto door lock function everytime i start the car the doors lock. how can i program it to disable this feature? is there a way to program it back just in case? i know there are a few alarm installers here so let me know. thanks!
Old Feb 6, 2009 | 10:07 AM
devilchrist's Avatar
do you have the manual? it tells you how to get to programming
but it's feature
1-3 ignition lock
1-4 ignition unlock
You'll need to find your valet swtich
to turn off the igniton lock feature
1. open door
2. turn key to "IGN" then off
3. press the HOLD valet button until you here "one" chirp, then release
4. Press valet button 3 times and release, then press again and hold (you should hear 3 chirps)
5. while holding press unlock button (two chirps turns off the "IGN lock"
6. close door to exit out of programming
to turn off the ignition unlock feature
1. open door
4. Press valet button 4 times and release, then press again and hold (you should hear 4 chirps)
5. while holding press unlock button (two chirps turns off the "IGN unlock"
Old Feb 6, 2009 | 11:07 AM
s2jeezy's Avatar
thank you! i will try this out right now. however not sure what you mean by turn off ignition lock and turn off ignition unlock.
Old Feb 6, 2009 | 11:16 AM
those are functions names.
Ignition lock = lock doors when alarm see's ignition
ignition unlock = unlock doors on when alarm lose ignition
does you car auto unlock when you shut off your engine(remove key?)
Old Feb 6, 2009 | 11:27 AM
s2jeezy's Avatar
ok i did both of those programs and it worked thanks. i got scared when i first did the ign unlock feature, it kept on locking at ign, but wouldnt unlock when i turned off ign. thanks i didnt know i had to do both. but do you know the codes do turn them both back on? just in case i wanna put back the ign lock and unlock feature. thanks
Old Feb 6, 2009 | 01:19 PM
same procedure. but lock button instead of unlock.
Old Feb 6, 2009 | 02:06 PM
s2jeezy's Avatar
ok thanks. ran into a problem tho. i think i was doing it wrong the first time, and now when i lock/unlock my car there is no beep. its always silent lock/unlock with the lights flashing.
Old Feb 6, 2009 | 02:17 PM
s2jeezy's Avatar
nevermind i found the installation manual online that has all of the programming codes. for some reason the shop never gave back the installation guide. thanks tho.
N1ck88
May 16, 2014 05:46 AM
jimbo69ny
Jun 27, 2013 04:34 AM
bruce0293
May 24, 2013 10:10 AM
revere
Apr 21, 2008 07:17 PM
WPS
May 14, 2004 02:39 PM
