Cannot auto start...WHY
Old Oct 1, 2009 | 11:01 AM
CKit's Avatar
Originally Posted by NFRs2000NYC,Oct 1 2009, 05:03 AM
Correct, and it's the most annoying thing in the world. If the convenience of remote start is THAT important to you, fine, but my friend has it on his car, and I would rather stab my eyes with pencils than having to do that everytime I get out of the car.
My friend, you must have a charmed life if THAT's the most annoying thing in your life.
90%+ it's set when I do my normal routine. If it doesn't set, I usually don't care enough to go through the motions of setting it... this may change when it gets colder.
Basically, I pull into a parking spot and pull the ebrake. Then I turn off the ignition.
That's it.
My personal habits include not releasing the brake pedal until the e-brake is up, so it works seamlessly for me.
What was your friend having difficulties with?
Old Oct 4, 2009 | 11:31 AM
IIXtremeHansen's Avatar
Try holding in the clutch autostart it. if i works than you can by pass it by taping up the sensor/switch down thats behind the clutch pedal.
Old Oct 4, 2009 | 07:34 PM
GrandMasterKhan's Avatar
Put the key in the ign (do not turn the key) and try to remote start the car. If the car starts then the issue is with your Immobilizer bypass module.
If no start: turn the key to the "on" position and try to remote start the car. If it starts then the issues is with your ignition harness wiring. (large gauge wires).
If the car still does not start then either your purple and green starter wires are backwards or not connected correctly or a fuse is blown on the brain's main harness
Old Oct 5, 2009 | 07:29 AM
Mother's Avatar
That's it.
I have the same set up and that's all there is to it. Park the car, put on the e-brake, then shut it off and get out. The engine keeps running until you shut the door to ensure that it is not in gear. There really are no extra steps than you would take when normally parking the car.
Old Oct 5, 2009 | 07:54 AM
Nsxnext1's Avatar
Originally Posted by PTHermes,Sep 29 2009, 06:35 PM
This is ALWAYS a bad idea on a manual transmission. Just one time leave it in gear and you have thousands in damage to your front end.
Old Oct 5, 2009 | 10:24 AM
The shut down sequence works pretty well. It will also disable the remstart if the door is opened or if the alarm is set off, it will disable the remstart.
So if you have a prox sensor it's pretty much impossible for someone to put the car in gear after you shut it down. (assuming you left the top down or windows and someone reached in to put it in gear)
PeteS2Kftw
Aug 20, 2016 04:22 AM
boys2k
May 28, 2015 01:48 AM
mikefifth
Apr 4, 2013 01:19 PM
w00tw00t111
Feb 27, 2009 02:20 PM
tms02
Jan 18, 2002 01:04 PM
