Deeper Speakers, how?
Old Jul 25, 2001 | 10:31 AM
Goldtrom's Avatar
Default Deeper Speakers, how?
Has anyone tried to put in 70mm deep speaker in the door?
How did you make them fit?
I was thinking maybe if I just added about 4 or 5 mm rubber ring inbetween the basket and the door... would that work? Would the front of the speaker hit the door panel? I seem to recall that the door had extra space between it and the speaker... more then 4mm?
Thanks in advance!
-- Robert
Old Jul 25, 2001 | 11:17 AM
mikes2k's Avatar
I used DynAudios 2 way comp set that has a 7" woofer. It is 77mm. I believe the installer used an mdf ring to make it fit. Rubber is not the best to spongy and will give and wear.
Pictures are here!
https://www.s2ki.com/forums/showthread.php?...&threadid=19475
http://homepage.mac.com/mikes2k/PhotoAlbum.html
Old Jul 25, 2001 | 12:57 PM
modifry's Avatar
Honorary Member
I don't remember the exact dimensions, but I put 6.5" Audax woofers wif large magnets in my doors. I removed the stock plastic basket (had to, the hole was too small) and made a spacer from 3/4" hardwood. I used counter-sunk screws to mount the spacer ring to the door using the factory holes, then screwed my speakers to the spacer ring.
Even with the 3/4" spacer they still cleared the door panels, but not by much. I think with the 3/4" spacer I measured just over 3" of depth available (76mm) till you hit the window glass.
Old Jul 25, 2001 | 03:11 PM
MacGyver's Avatar
Gold,
You could always do spacers (although I wouldn't go for anything thicker than about 1/4" as the panels might start to bulge), but if you want to put in a little more work, try working with the window. The part that holds us back from a deeper speaker is the leaf-switch stop attached to the window (the white round thingy). I'm sure anyone with a reasonable size set of cahones could remove the window, drill a new hole for the white thingy, move the leaf switch, and VOILA...instant extra 1/2" mounting depth. The spacer would certainly work, but for those cases where you need a LOT of extra depth...
Old Jul 25, 2001 | 06:25 PM
shaner's Avatar
I installed my Dynaudio 7" woofers (just like Mike) with 1/2" MDF rings between the basket and the door and I have had 0 difficulties with the window/woofer...
Mikes2k,
Did your installer have to "shave" a bit of door steel to make the Dynaudio woofers fit? Just curious... I had to...
Old Jul 25, 2001 | 09:02 PM
S TWO K's Avatar
I used 5/8 Pine shelfing (yes!) to make my adapter rings. I chose pine because it's easy to work with, and doesn't swell up like MDF or particleboard.
Even with my Sony 3 ways, I still have a bit of room.
Old Jul 26, 2001 | 06:19 AM
mikes2k's Avatar
[QUOTE]Originally posted by shaner
[B]Mikes2k,
Cheers!
Dec 5, 2015 11:07 PM
SeanStone
Jul 4, 2013 01:03 PM
flexctacy
Feb 11, 2010 03:15 AM
DBXFX
May 19, 2008 07:59 PM
RWIRSING371
Oct 29, 2001 11:55 AM
