Headunit shopping... recommendations?
Old Mar 26, 2009 | 12:27 PM
  #71
ZSAK's Avatar
actually, my crossovers are in the door as yours, and I do have a dedicated 4 channel amp already running the door speakers as well. So it seems like it may not be too bad to do then
Old Mar 26, 2009 | 02:16 PM
  #72
Neutered Sputniks's Avatar
Should be a simple 2nd run of speaker wire to each door. Given that your channels are probably paired (1&2 adjusted together and 3&4 adjusted together), make sure that you wire your woofers into 3&4 and your tweeters into 1&2 (or vice versa, depending on channel power output).
Old Mar 26, 2009 | 02:22 PM
  #73
[QUOTE=nr7,Mar 26 2009, 04:16 PM] does 5030 fits well in the s2000? can 5030 run active? i need BT so..9887 and 800 is out of. only 5030 and 700 or 710 pioneer premier. but for now i want to use under seat sub from jvc or boss.
Old Mar 26, 2009 | 06:41 PM
  #74
nr7's Avatar
nr7
so the intergrity mag v4 can use with 4 ch amp or has to be 2 ch only? i'll look into darkside subs enclosure in spare well place. last time he was not accepting any orders.n and i checked darkside's website and couldn't find spare wheel sub. tool well and side trunk subs (v1 v2 and tool well) only. where can i get one if he doesn't make one?
Old Mar 26, 2009 | 07:40 PM
  #75
Ankur194's Avatar
Clarion fz709 looks pretty nice. Got a kenwood x592 myself, like it just fine..cheap and chearful
Old Mar 26, 2009 | 07:41 PM
  #76
nr7's Avatar
nr7
hi neutered do you have pic of ur sub in the spare wheel place..i did searched for the pic and couldn't find it. i only found for ur truck i think. jst to know how it looks like in there. thanks again..
Old Mar 26, 2009 | 08:59 PM
  #77
I apologize for the confusion. My sub is mounted in the trunk well.
If you decide to go active, you'll need a 4-chan amp for the doors and a mono amp for the subwoofer. If you stay passive, you can use a single 4-chan (2 channels for the doors, bridge the other 2 for the sub).
watermelonman
Jun 4, 2014 07:39 AM
[AP2-2NV]
Jan 3, 2007 06:01 PM
trainwreck
Oct 31, 2006 02:16 PM
Brownergy
Jun 30, 2006 07:53 PM
malaguti
May 20, 2005 08:25 AM
