help with alarm install
Old May 20, 2007 | 05:37 PM
SoCalIsMyLife's Avatar
Default help with alarm install
hey it says the door open trigger wire is black/white on the keyless entry module harness. however, there are two black/white wires. do i connect the green (ground signal) wire from my Clifford to both of them?
Old May 20, 2007 | 05:54 PM
GrandMasterKhan's Avatar
test them with a multimeter do find out which one is the correct one...... and If you dont have a multimeter you shouldnt be doing the install.
Old May 20, 2007 | 06:09 PM
i have a multimeter. it reads 0 the whole time
Old May 20, 2007 | 06:18 PM
of course it will. The wire is negative trigger.
In other words when the door is open the wire tests as a ground.
So you need to set your multimeter to test for ground with a tone. (ie when both your tips read the same groun it will sound a tone)
or if your multimeter doesnt have that fuction. tap the negative probe to the wire you want to test and the + probe to 12v. When the door opens you should see 12v.
BLAQ&GREYs2k
May 30, 2013 06:23 PM
S2KCHRIS305
Aug 15, 2012 10:05 AM
AP1Drew
Jan 19, 2012 04:40 PM
jonneson
Apr 27, 2010 01:16 PM
dyhppy
Jun 20, 2005 11:36 AM
