Help with rsx sub!
Old Aug 11, 2004 | 06:01 PM
r_duff's Avatar
Default Help with rsx sub!
Hi all... Im getting an rsx sub sent to me. My question is... how does it install? Im assuming 2 line imputs (+ and -) and a power lead (remote also?). I was wondering if its possible to splice rca lines to the signal leads and plug them into the back of my alpine 7893, so i can use the independant sub woofer controls. any thoughts?
Old Aug 12, 2004 | 03:34 AM
STL's Avatar
STL
In the future you might try doing a search before starting a new thread. I know I started a rather detailed thread about it over a year ago.
Here is:
http://forums.s2ki.com/forums/index.php?showtopic=123602
Old Aug 12, 2004 | 05:05 AM
PokS2k's Avatar
This is link has alot of the wiring info.
Bose sub wiring
Old Aug 12, 2004 | 09:45 AM
r_duff's Avatar
thanks. quick question. if the orange wire is the 12v lead, doesnt it drain the battery when the car's off? since there is no rem. hookup? My sony amp (for front speakers) are wired directly from the battery, and has a rem line to shut off the amp when the HU powers off. I suppose then, that I cannont use this same 12v lead?
Old Aug 12, 2004 | 10:35 AM
PokS2k's Avatar
I added a swtiched relay.
Old Aug 17, 2004 | 12:32 AM
Jason B's Avatar
Can you give me some instructions on how you hooked up the switched relay to the bose sub?
I hooked mine up without one, (the unit was supposed to have an autosensing power ON, when music was detected) but it doesn't work on mine and drains the battery.
Thanks
Old Aug 17, 2004 | 05:01 AM
PokS2k's Avatar
Thanks
I don't believe there is a sensor built in.
Here is the wiring I used. I bought a 12V 30A automotive switch relay from Radio Shack.
#30 - Constant 12V (+) Always live
#86 - Ground
#85 - Remote Amp Turn on from Receiver (Switches the relay on and off, allowing the juice from #30 to go to #87) Your HU needs to have an Amp Turn on lead.
#87 - Juice to Bose Amp.
I also put an inline 10A or 15A fuse in the 12V line.
Old Aug 17, 2004 | 09:38 AM
Jason B's Avatar
Thanks, now, I forgot to mention, I'm using the factory deck in my 2002. Will anything change?
Old Aug 17, 2004 | 09:53 AM
PokS2k's Avatar
Don't know the stock HU's wiring. You can get a 12V line from tapping into the stock HU's line, the fuse box or the battery.
Here is a link to MacGyver's website which shows the wiring harness for the stock HU. I think you would tap into line 1 for the remote turn on.
HU wiring harness
DangerZone9K
Feb 19, 2011 12:49 PM
B.Money
May 14, 2007 10:29 PM
Kenpo_S2000
Oct 30, 2006 08:44 PM
marc r
Nov 4, 2004 12:52 AM
toosteeley
Jun 7, 2004 08:09 AM
