I am so confused. need help!
hello!
I was looking through F/S section and found something I liked.
it's a infinity component system.
http://www.infinitysystems.com/car/product...y=US&Region=USA
and then I found out it includes 2 x 6.5 woofers, 2 tweeters and 1 cross over.
then I was thinking
'wait...I need two front speakers not 2 woofers.'
and then I was reading through few posts and found out people actually use these component systems.
please enlighten me...
is woofer the same thing as speaker?
does that component system have everything I need to upgrade my audio system? (except it doesn't have amplifier)
thanks guys!
then I was thinking
thanks guys!
The woofer is the big speaker located at the bottom of your door.
The component system box should come with everything you need, except for a way to connect it to the stock wiring. For this, you have 2 options:
1.) Run new speaker wire for the components
2.) Purchase the Honda speaker harness pair, cut the speaker harness lead connectors, and connect these to the input connections on the crossover from the new set.
Originally Posted by kakahoya,Mar 6 2007, 07:27 PM
thanks a lot!
I thought woofers were subwoofers...
So the sub-woofer was designed to fill in where the "mid-woofer" falls short. The small woofer produces enough bass that it can't rightly be called a "squawker" yet it doesn't have the "oomph" to be a real woofer. So it's a mid-woofer.
b0mbrman
Feb 20, 2003 08:02 AM
