Installing 2 additional accessory outlets ?
Old Mar 14, 2007 | 03:56 PM
wasupdu's Avatar
Default Installing 2 additional accessory outlets ?
I hardwired my radar detector directly to the fuse box but now I also want to install 2 accessory outlets under the dash in the same area since I want to install my XM Sportscaster and Garmin Nuvi 350.
How do I install the 2 cigarette lighter receptacles since my radar detector is occupying the the appropriate spot in the fuse box (ignition) ?
I hope this makes sense.
thanks for your help.
Old Mar 17, 2007 | 07:15 AM
imdarkrider's Avatar
get a relay.... get 2 cig plugs... mount the plugs where you want... ground the one side , take the power side to the output of the relay , put the input of the relay to 12v constant , from your ignition harness would be ideal. one side of the switch of the relay to ground , then the other side to 12v turn on - otherwise known as ignition
EOE
Jun 5, 2020 01:18 PM
bs-inc.s2k
Jul 30, 2012 06:59 PM
Mr. Francesco
Sep 25, 2005 11:42 AM
SiCK HONDA
Apr 18, 2005 10:36 AM
devi0us
Jan 17, 2003 06:22 AM
