Interior And Trunk Lights Not Working?
Old Jul 14, 2004 | 06:12 PM
Icemn2003's Avatar
Default Interior And Trunk Lights Not Working?
Hey, my trunk light's been out for a while now, thought it may be the bulb, but today I realized that my dome light is out also. Are they on the same fuse? If so, that'd probably explain the problem, but if now, I have NO idea.
Thanks in advance.
Jason
Old Jul 14, 2004 | 06:20 PM
DJDeeLuxx's Avatar
its definatly a fuse... the fuse is goin to be in 1 of 2 locations.. either under the hood or under the drivers side dash board... same thing happened in my car when i installed neons in my trunk....
Old Jul 14, 2004 | 08:02 PM
Icemn2003's Avatar
Don't suppose anyone has a fuse diagram handy which could show which ones I should check???
Old Jul 15, 2004 | 12:08 PM
xxjdxx's Avatar
the fuse diagram should be in your owners manual!
Old Jul 15, 2004 | 12:24 PM
modifry's Avatar
Honorary Member
Fuse 24, under-dash fuse box. The right column of fuses has the top fuse missing (I think), that's fuse 28. Count down to the 4th fuse slot from the top, which should be a red 7.5 amp fuse. The 3rd slot down also has a red 7.5 amp fuse - that's the ECM memory. The one you want is below it.
There should be a white fuse puller and spare fuses in the fuse box.
Old Jul 15, 2004 | 01:52 PM
Icemn2003's Avatar
Thanks for the replies, guess I knew the fuse was in the manual (doh), I'll check it out next chance I get modifry, thanks for being so specific too...love this site!!
Old Jul 18, 2004 | 08:29 PM
Icemn2003's Avatar
I checked today, you were right Modifry, it was the fuse, but it was the #17, not the #28. Nevertheless, thanks for the help, I appreciate all the inputs!
Bardown91
Oct 5, 2014 02:05 PM
RylisPro
Jul 2, 2012 04:33 AM
dsddcd
May 15, 2009 03:12 PM
FOXCONN4
Feb 19, 2007 03:19 PM
Fougeee
May 15, 2006 07:35 PM
