iPod dock - what is a good choice and where should
Old Sep 8, 2005 | 01:25 PM
more_teens_need_sportscars's Avatar
Default iPod dock - what is a good choice and where should
ok, im getting an s2000 soon and i always use my iPod to listen to music in my car, i was just wondering if anyone knows what some good docks would be to use and where i can mount it. i dont like those ones that take up ur cupholder, '00 doesnt have one anyway.
Old Sep 8, 2005 | 03:16 PM
cjw07's Avatar
Hey more_teens_need_sportscars
I have a Neo Ion, which is actually a Dension. It is great, easy install. here is the link to my install and a pic.
https://www.s2ki.com/forums/index.php?showtopic=301488
Happy Ipoding
Chris.
Old Sep 8, 2005 | 05:03 PM
thanx for the install pics. did that come with the holder? cause im looking at the alpine unit right now and i wasn't sure if they came with the dock/cradle. whered u get urs and how does it mount
Old Sep 8, 2005 | 06:29 PM
cjw07's Avatar
the Neo Ion doesn't come with a dock, the Dension Ice Link does.
The cradle i am using is the one that came with the ipod, i just cut off and filed down the clip on the back and mounted it on a wedge. sits in nice and tight.
Hope this helps.
Chris.
Old Sep 9, 2005 | 06:46 AM
magikcow's Avatar
I routed mine through a drilled hole in my golvebox. it's held in place by the elastic band. This way it keeps out of the sun and out of sight.
Old Sep 9, 2005 | 11:50 AM
TRR's Avatar
TRR
That's how I have mine mounted also.
TRR
Old Sep 10, 2005 | 12:14 PM
airborne.s2000's Avatar
I also routed mine into the glovebox. Here is a pic of the install.
I bought one of those sticky pads that are sold in the iPod accessory area at Best Buy and cut it to fit the spot under the elastic band. I drilled a hole in the back of the glovebox and ran the cable up to the iPod. You can't see the hole since modifry's glovebox organizer hides it.
Old Sep 10, 2005 | 01:07 PM
BlueDevil34's Avatar
I like the proclip mount a lot - it mounts to the left of the shifter at about a 30 degree tilt. Very easy to see and operate without being too distracting. I use it with the neo ion. The total setup is a bit pricey for what's basically a couple pieces of plastic and an adapter cable, but worth it.
www.proclipusa.com
www.mp3yourcar.com
Old Sep 10, 2005 | 03:57 PM
S2KSuzuka's Avatar
I like it hidden and out of the way. Alpine makes an adaptor that allows control of the ipod form the radio itself
Here's where I put mine
Mitch
1st mod- before the adaptor
My version of the amp rack. It bolts down using the Spare tire Bolt. The JL 500/5 fits behind the bold for easy access. I mounted my XM tuner on the bottom side of the rack
stv1991
May 13, 2011 07:41 PM
Toecutter
Aug 23, 2007 04:54 PM
funnyesq
May 2, 2005 03:59 PM
jshmoe
May 20, 2004 11:00 AM
bigfecker
May 12, 2004 06:53 AM
