Mounting Solutions
Old Nov 12, 2009 | 07:01 AM
roy365's Avatar
Default Mounting Solutions
I have my car torn apart and before i go running wires and doing any permanent or semi permanent installs i wanted to get a few opinions or tips if you would.
I had the OEM Sirius interface and antenna unit mounted in my trunk previously. I just installed my aftermarket HU and DCI. Now i want to see where you guys have mounted such on your S2K's for easy access or best place.
I have the Alpine interface & the antenna unit to mount. Both boxes are ~5''x5''.
Behind the radio area is a no go for sure. No space.
So how about the area where a glove compartment would be?
Any spots you guys found that will work?
Old Nov 12, 2009 | 08:41 AM
HiVolume's Avatar
I put the XM radio module int he passenger side kick panel and the antenne on the dash (center, near the windshield).
Old Nov 12, 2009 | 11:01 AM
MikeyCB's Avatar
I have my Sirius Antenna on the secret compartment behind my rear windscreen. My Sirius dock is installed in the front bin of the secret compartment where I can pull it out and take it inside my house, put in a rental car, etc. It's integrated with my alpine deck so all the info and controls are in the headunit.
Old Nov 12, 2009 | 11:21 AM
roy365's Avatar
Thanks for the reply.
I see you have an Alpine HU as well, so you should have the same 2 interfaces/boxes i have to mount. Correct?
So my antenna is mounted on the trunk. The wire is run up through the cabin. Now my question/issue is where to mount the 2 boxes. I will have to check the "kick panel" you are referring to. Its on the right, where an ECU would be for a RHD car right?
Old Nov 12, 2009 | 04:07 PM
DaPhatty's Avatar
Great thread! I was just about to ask something similar except it was regarding HD Radio. Gonna subscribe to this one. Let us know how it ends up! With pics if possible.
Old Nov 12, 2009 | 08:29 PM
HiVolume's Avatar
[QUOTE=roy365,Nov 12 2009, 12:21 PM]Thanks for the reply.
Old Nov 13, 2009 | 03:35 AM
roy365's Avatar
[QUOTE=HiVolume,Nov 12 2009, 09:29 PM] Indeed, check behind the passenger side's "right foot" panel. I used 2 way tape. Another spot that worked out for the Alpine<->XM adapter box was behind the panel that is below the passenger side airbag. Be careful when you remove that panel, the clips break quite easily (broke it twice... Doh!
Old Nov 14, 2009 | 07:53 AM
HiVolume's Avatar
Here's a shot of the Alpine adapter behind the panel below the passenger side airbag (note that the A/C + blower unit is removed in this shot, which explains the huge void, but it fits even with the unit):
Like I said, I chose to put the main module in the passenger side kick panel. I could have put it in the same location as this adapter, but wanted to use that space for other goodies.
Old Nov 14, 2009 | 10:34 AM
street_ruler's Avatar
nitrous i see
Old Nov 18, 2009 | 08:36 AM
HiVolume's Avatar
Originally Posted by street_ruler,Nov 14 2009, 11:34 AM
nitrous i see
That line is the A/C line I custom made during my accessory tuck. I do have CryO2 though.
(without wanting to hijack the thread, here's an engine bay shot)
Carson07S2K
Apr 26, 2009 03:42 PM
Carson07S2K
Apr 16, 2009 11:10 PM
TJeep_1999
Mar 24, 2006 02:34 PM
bdoob
Jun 16, 2005 09:46 AM
mattnyu99
Apr 11, 2005 07:04 PM
