One Touch Power Down
Old Jun 22, 2007 | 11:04 AM
webmasterino's Avatar
Default One Touch Power Down
Can the passenger door window switch be changed with the one-touch down by replacing the actual switch? Has anyone tried this before? What about replacing the passenger switch on the drivers door for one touch operation. The window goes down automatically with the top so I figureed why not?
Also, is there a way to lower the top using the remote such as instead of unlocking the trunk? I always use engage the emergancy brake so that is a mute point for me.
Old Jun 22, 2007 | 11:13 AM
tukluc's Avatar
Do you also leave the top unlatched when it is in the closed position? Otherwise, you have to be in the car to unlatch it and at that point, what function does a remote serve when all you have to do is flip the switch?
Old Jun 22, 2007 | 12:47 PM
Saki GT's Avatar
I installed a DEI 530T module - it gives me one-touch up and down windows on the driver's side. Its also wired into my aftermarket alarm so I can remotely lower and raise the windows, and the windows auto up when I arm the alarm. Plus, if I'm raising the windows with the module, I can shut the car off and they will continue to go up.
As for the top, since you have to latch it manually, I just do it manually.
Old Jun 22, 2007 | 03:13 PM
Boofster's Avatar
I am also interested in changing the two non-auto switches to the main driver switch if this works.
Old Jun 22, 2007 | 03:17 PM
sean2sean's Avatar
yup... the dei module works... ive installed it and it works like a charm.
Old Jun 22, 2007 | 07:59 PM
Latch?
Had to point that out, eh?
chrisesteban
Jun 20, 2006 04:12 PM
DJFriar
Apr 4, 2006 09:11 AM
Polemicist
May 24, 2003 01:01 AM
dterry
Aug 13, 2002 03:00 AM
Eleanor_01
May 15, 2001 04:21 PM
